Cheap Watercooling Hard Line Fittings
20 Oct 2002
Derby
I am sure I will get some flack for this, considering what they actually do. Anyway, has anyone tried the cheapo watercooling/hardline fittings that are floating about from a company called Q&Y Freeze?
Here is a link to the ones I mean http://www.ebay.co.uk/itm/4-pack-Br...%3Ae38ba69615c0aa472ced3213fffcfa93%7Ciid%3A1
I am thinking of getting a couple of sets as they work out cheaper than most other fittings they also look VERY similar to XSPC Fittings. Obviously I would change the O-rings for some better quality but for the money they don't look too bad.
I never heard of those ones but I went with the Barrow fittings and they are basically the same as Bitspower and cost me hundreds less.
