I'm getting a bit of work done in my house and am moving on to the living room next.
I've currently got a double radiator which is marked on the layout, however because my house is a single brick with no insulation it gets bloody cold in that room. It's also not helped that a sofa blocks the radiator.
I've used the online calculators and I need about 8000 BTUs to comfortably heat up the room.
http://i.imgur.com/ijtwEnN.jpg
On the left wall is where all my media is, so I can't put a radiator on that one unfortunately.
I'm thinking about putting 3 radiators linked under the bay window, it's quite difficult to get a angled radiator.
The other thought which I'm not that keen on is to put a double radiator under the middle section of the bay window and then another smaller radiator opposite on the internal wall. I hate this idea as soon as your open the door you'll see the radiator in front of you.
So lads any ideas?
So lads any ideas?
