I'm delayed (again) at ZRH, there isn't much else to do!I'm impressed you counted them!
Have you been trained to use a Stihl-saw?![]()
Unfortunately common sense isn't all that common* and you have to allow for the idiots who would otherwise try and take shortcuts which put people at risk.Fair enough, if you're working on an oil-rig, on a ship, down a mine, atop a skyscraper or some other such dangerous workplaces I'd expect a good few days of lectures explaining the safety situation and regulations. But I ******* detest what H&S is these days in everyday mundane jobs. I mean, whatever happened to common-sense? I **** you not, when I worked for the local council we had to sit through a two hour H&S lecture on how to safely change the paper in the laser printers and photocopiers. There were many, many other such stupid lectures too. We actually had one about leaving pencils on our desks.
If you ever feel like keeping your mouth shut in the face of a potential OHS issue, fire up ******** and take a look at some of the workplace accident videos there.
Do you know the supervisor isn't qualified?
Perhaps the 'peon' who was sent up is qualified? Are you again certain that he wasn't?
I suspect it doesn't matter for DIY jobs (we've got some my dad used to use to paint the walls*), but in a work environment it'll be different if just for insurance reasons.I personally had no idea there were qualifications in building scaffolding.
Guess I won't be doing that again.
I used to work with a girl whose husband was a builder, doing big steel framed glass buildings. He used to say that there was no way you could follow all the H&S guidelines and play by the rules and get the job done in time.
He ended up putting his hand into a circular saw and severing the tendons in his palm. Go figure.
A big problem here is that rather than complain it can't be done, then fail to do it in time, most will complain it can't be done on time, do it on time by ignoring health and safety, then tell management they adhered to all the guidelines. The end result is management that see a job done, apparently properly but by a moaner.I used to work with a girl whose husband was a builder, doing big steel framed glass buildings. He used to say that there was no way you could follow all the H&S guidelines and play by the rules and get the job done in time.
Indeed.A big problem here is that rather than complain it can't be done, then fail to do it in time, most will complain it can't be done on time, do it on time by ignoring health and safety, then tell management they adhered to all the guidelines. The end result is management that see a job done, apparently properly but by a moaner.
They make a rod for their own back.
H&S has gone mad in the UK.
It is used to inflate prices. Ask any one in the building trade.
I did just that and there is a vid there of 2 blokes up a tower scaffold cutting a beam, the beam drops but stands vertical then falls against the scaffold knocking it over. Luckily they were harnessed to something above the scaffold.
better to deflate prices by paying the difference in blood then?
Yes, because sitting through 8hrs on the downfalls of badly placed pencils on a desk, sharpening of pencils is really worthwhile.
