Motorola Moto G5 16GB/2GB Ram Sapphire Blue on Pay As You Go
8 Nov 2002
Kent
Just got this phone and need a nano sized payg sim. I tried my old payg sim but its standard size. What is the best payg sim and is it possible to retain old number?
Assuming you get decent coverage then I'd suggest 3 PAYG as they're reasonably cheap compared to many others. Generally you get a 3 SIM then simply use their online form to request the number transfer. However you need the PAC from your current SIM provider to proceed with the transfer.
How do u change the picture which is seen before the phone is unlocked? First wallpaper has stuck there after taking the micro sd card it was stored on out and battery. Under display>wallpaper it only changes the wallpaper displayed after unlocking the phone
for that i think there will be a file available on root something along the lines of backgroundwallpaper. i think that is the file that stores the bg wallpaper when the phone is locked. im not sure on its mechanics though as this file appeared when i set the lock screen wallpaper on android 4.4
