- 3 Mar 2009
Hope this is the right place to put this, if not please can it be moved ?
I purchased a GPU for my brother in December 2015, Zotac GTX 970, comes with 2 warranty and the card was bought from a company that sounds like Scam. A couple of months ago it developed a fault where, 1 of the fans spun slower than the other, causing the other fan to go into overdrive and create a loud noise. Looking it up, it seemed to be a common issue with these cards, and a fan replacement would fix it.
Contacted Zotac first to see if they could simply send out a new fan, but they refused telling me to go through the RMA route from who I bought it from.
Ok, set up the RMA, sent it off, they diagnosed the fault (faulty fan) and sent it off to be repaired through Zotac.
A month and a bit more passes with no update, so I ask again, I'm told it does seem to be taking a while, but as the card is no longer being made it can take a little longer, and to expect something within the next 2 weeks.
2 weeks pass, and nothing, so again I ask what is happening. This time they tell me they can offer me a "benefit of use refund", which would be about a £96 refund for the card. I wasn't happy with this (and told them so), as that isn't enough to cover a replacement card for even a second hand 970, but was told this was more than my legal entitlement and they could do no more. Before I had a chance to reply, the chat was ended.
Now, to me, this doesnt sound right, I shouldn't be worse off than I was before, but I'm hoping someone know a bit more about this to see if what they are offering is right, especially when the card still has months left on its warranty. Am I being a tart ?
And yes, if I bought it through OcUK I probably wouldnt have this problem
