aorus gaming 7 case fans
I'm guessing MB Fan #1 is the H100i v2's fans. They may be connected with a splitter so you just see one fan reading.
GPU and Pump RPM speak for themselves.
Not sure what's going on with MB Fan #4 and #5 lol. Could be a false reading, or could be those 2 case fans you say don't change speed.
the h100i v2 has a fan reading though it does work but i set it to come on under heavy loads as its pretty loud to have 24/7 - but idle temps without it are fine, gpu is at 28degrees and cpu cores are all 28-30 degrees
under heavy load which at the moment is only battlefield 1, 4k, 120fps, ultra, 60mhz the temps are - with all fans running gpu - 65 after about 2 hours it starts creeping to 70+ plus, and the cpu has never gone above 60
so i think i just need to move the hot air off of the copper back plate and it should be good, but from what i've heard these new corsair fans are extremely powerful (they go higher than my gpu ones) but loud, a lot of reviews also said you only really need to due to them being so good so finger crossed haha
That's not too bad to be honest. But at the same time, gaming temps should stabilize after a few minutes and they shouldn't get hotter after a few hours, so yeah maybe it can be improved. Hope it works out.
hopefully, if these fans are any good i think i'll replace the rest of my pc with them as they are a pretty good price, anyway thanks for all the help
i only have one of the fans in my at the top as the other fan slot is stupidly hard to get to but with just one at the top under full load my gpu temps are at 60/61 instead of 70+, i think later this year i will take my pc to overclockers and have them replace all case fans with these ones, hopefully upgrading parts wont void warranty
ok so under load all case fans are max and gpu's fans are near max i think 80% and load temps are 61/5 max and this is during summer to, is it ok to game with the fans this high? im guessing it will be as these are performance mode in corsair link
Me personally I'm fine with 75C on hot summer days, around 70C the rest of the time. And I use Afterburner to control GPU fans with a 1:1 ratio, so max RPM is 75%.
ah ok i was told to never go above 70 or theres a issue with the card/fans, if i keep my stock gpu fan curve the temps stay at around 75/76 i was trying to keep mine around 60ish
That's probably because your card throttles speed slightly above certain temperatures. It would impact benchmarks most, maybe cost you 1-2 fps in gaming.
But safe temperature-wise, it's okay.
You could try setting a custom fan curve to fine-tune, because the stock profile will be very low, optimized for quiet. Whereas the performance profile might be a bit noisy at 80-ish? If you don't have a problem with noise then all good.
its the aorus 1080ti xtreme 11g - yeah i have all my case fans on full during gaming and gpu at 80%, sounds not an issue as i have studio style headphones
