My Background
Board Background
Here is the fun part, most of these are not even in the real ballpark, because unlike the ASUS boards that read the real CPU temperatures.
my X99 ASUS CPU temp is 55C The temp really is 55C
Here My CPU Temp is 65C It thinks its 45C
Gigabyte use their own sensors as reference.
So
When my 1800X is 64.5C
Gigabyte BIOS thinks its 49C
now the CPU sensor varies by 15.1-15.6C
When My GPU is 79C
Gigabyte board things its 55C
the GPU Sensors varies wildly. 8-24C
adding to this THE UEFI mouse control is very Hit and mis, fast to wont move at all means making fine adjustments are impossible, & you cannot enter in numbers manually like the ASUS QFAN
Why is this bad?
some of you may know that i'm a silence freak & i Try to use Ultra Low RPM to get quiet system.
i wanted to make users like me aware of the pitfall of The Aorus board. I will be in contact with gigabyte to report these issues & hopefully help them resolve such a terrible user experience
I recently Purchased A Ryzen 7 System. & and a gigabyte Am4 Gaming 7 Motherboard.
I was either going to get the ASUS or Gigabyte board due to Smart Fan control features.
Board Background
However it turns out Gigabyte Smart Fan 5 Bios feature really is Annoying Fan 5
After Hours of testing this is what i found out
CPU (Tdie) is the 1800X - the 20C offset
CPU (TCtl) is the 1800X with the 20C offset
The gigabyte board allows you to adjust the Fans with the following sensors
CPU
GPU
VRM
So
When My GPU is 79C
Why is this bad?
because the sensor reads so low
My CPU is 44C? really its 64C making me need to run high Fan Profile at 44C
THis Make the user Require to work out the Offset of 15.1-15.6 For entire Fan Profile
Then 8-24C for GPu Profile
