Same old rubbish about drivers, even although that has been proven wrong by AMD themselves.
Yah mate whatever. I suggest do not start to read tech sites which proved the features not working, voltage scaling not working
Consider the evidence and think about it logically - the only evidence we have at the moment is:
1) Vega is no better than Fury at the same clock speed.
2) Vega can clock higher than Fury.
3) Vega has huge power consumption and runs very hot as a result.
Is it really logical to assume that a couple of months of driver development will bring big enough increases to performance and big enough decreases to power consumption to make Vega better than a 1080?
Your first point is the actually point to the driver issues. Vega has tons of upgrades even above Polaris, and yet still not faster than Fury...because it is running basically on the same modified Fury drivers as i said a few time.
Tiled rendering one of Maxwells main energy saving feature was - inactive in Vega.
AMD automatic voltage regulation AVFS (automatic voltage and frequency scaling) - inactive in Vega - thus the huge drops in power consumption at undervolting (Gamersnexus dropped to 1100mV from 1200mV and that was 87W less power consumption)
No it wont be better at power consumption/performance than the 1080, it will probably be worse than the 1080Ti, but not this much.
Also take into consideration that every new architecture needs it's drivers to mature. Look at Ryzen, it started as a "bad for games" CPU, and in a few months it gained 2 digits of FPS in many games
