Thanks, that's really helpful info being rather tall myselfWhat's the deal with wires, is there any cable management?
I've been fairly lazy with cable management on the WSP and the Playseat and neither have anything particularly clever to handle the wires, but I've found it slightly easier to keep wires out of the way on the Playseat.
You just need a straight piece of metal u-shaped that will fold around the deck the wheel sits on inside the mouth of the wheel clamp which then sticks out one end either side of the wheel, just add blu tak to avoid slippage...
I had the old playseat office chair and bought the shifter mount for like £35 then when i got it I realised it was just a metal bar as described...it works but it can come a little lose if you go aggressive on the shifter.
You can see it in the pic here...
http://www.playseat.com/shop/eu/wl/playseat-challenge-racing-seat-gearshift-support.html
I've seen that and have been meaning to just get something myself for much less, I just need to get around to it!
