- 15 Jun 2007
- Manchester
Hi folks, been pulling my hair out over this all morning, any help appreciated!
I have standard ADSL through an EE Brightbox modem/router, which for the past 2 years I used with an Asus RT-N56U with no issue. Over xmas the Asus router died so I bought an RT-N66U (basically the same but bit better) from a forum member here.
Now, the router appears to work fine, the problem is connecting it to the Brightbox. I'm positive I remember originally putting the Brightbox into 'bridge mode' for the purpose of using it as a dumb modem, however I think a sneaky firmware update and hard reset has removed this option since it now doesn't have it unless using fibre, and I had to hard reset recently so I don't know what the config was.
As far as I understand, all I should need to do is turn off DHCP and NAT (and anything else I don't want like firewall etc) on the Brightbox, put it on the same subnet as the Asus router and happy days.
So I have the Brightbox as 192.168.1.2 on the 192.168.1.xxx subnet, with DHCP off but a reserved IP of 192.168.1.1 for the Asus router. Asus router is plugged in via it's WAN port and it shows as a connected device on the Brightbox status page.
However, the Asus router (192.168.1.1) can't communicate with the Brightbox at all.
It fails to auto-detect internet settings or a WAN IP, which the previous one always did - this is no suprise given the router cannot even ping 192.168.1.2 (Brightbox). I can't fathom why it can't communite with 192.168.1.2 even though the Brightbox itself is somehow communicating with it as it knows it's an attached device.
I've tried combinations of enabled/disabled DHCP, NAT and firewall to no avail, also tried the various connection types on the Asus router inc static IP etc, no luck.
anyone had experience of this kind of issue?
Cheers
Cheers
been years since I had to do any practical networking
