So I'm in an ok position and last year started to shove a fair bit in to my personal pension.
My pension provider gives me an auto top up of 20% - so say I put 160 in, my pot ends up 200 better off. This is because contributions are tax free and should be from source.
I've just done my self assessment and plugged in my contributions to my personal pension (adding on the 20% the provider adds, as it says I should do).
The return states I have X amount as an overpayment. Which is 20% again atop of the above pension contributions. So basically you are getting you contributions into you pension as though it was from source - basically getting your tax back.
Question: How does this work? Do they just return the rebate to my account? That doesn't make sense, as I could then push that money in to my personal pension and then "claim" the 40% again. 20% automatically added by the pension provider, and another 20% when I do my SA next year.
Can someone clarify? It would make sense if the rebate from the SA went straight to my pension provider but that isn't the case I don't think
