Corsair 16GB 3200MHz using less than 3000MHz Issue
2 Nov 2015
Kent
RAM: Corsair 16GB White Vengeance LPX DDR4 3200MHz RAM/Memory Kit 2x 8GB
I have tried different software to work out the speed of RAM, however, I still don't get the maxed 3200MHz. I have enabled XMP in the motherboard but it doesn't seem to have changed anything.
Is there something I am missing or doing wrong or at least reliable software I can use to check everything on my computer?
Cheers,
EDIT: Specs
Processor: Intel Core i7 6700K @ 4.0GHz
Motherboard: Asus Z170-A
RAM: 16GB DDR4 Corsair @ 3200MHz
GPU: GTX 1080TI 11GB
Do you have a screenshot of one of the programs showing your ram speed? CPU-Z is one of the go to programs.
I have downloaded the software that you have suggested.
I believe you have to times the DRAM Frequency by 2 = 2934.2?
Cheers.
Is there anything like XMP 1 and XMP 2 options?
And with no XMP, what happens when you try to set the frequency and voltage (1.35v looks like) manually?
Have you updated your MOBO BIOS to the latest non-BETA version? Try that, and if the issue isn't resolved, try contacting our Coorsair Technical Support staff, and we can help get this resolved.
