No video output from Gigabyte GA-AB350M-G3
  • Thread starter Thread starter Ed
  • Start date Start date
Ed
Ed
28 Apr 2004
Hastings
Hi everyone,
I've just setup a Gigabyte GA-AB350M-G3 with a Ryzen 5 1600 and one stick of 8Gb 2400 Corsair RAM but I'm not getting anything from the mobo's HDMI or VGA port to the monitor. The stick of RAM is placed second from the CPU.
The keyboard's num-lock and caps-lock works so there's some signs of life but I wonder if you chaps have any bright ideas of things I'm overlooking?
There's no GPU in there yet either, if that helps.
Thanks in advance.
Someone correct me if im wrong..but does Ryzen not have integrated graphics, and needs a dedicated GPU??
The board has VGA and HDMI outputs on it so I assume it does. A mate is going to lend me an old PCI-E card tomorrow just in case.
I'm kind of relieved that a GPU will/should fix it and I don't have to go through the hassle of sending stuff back. Very odd it has on-board video output yet is incapable of doing so.
I would be but also would be mad that it gives the imprsession that it has onboard graphics.
quote from there web page.
4K resolution is the next technological milestone in high-definition content delivery, utilizing approximately 4,000 pixels on the horizontal axis, more than four times today's standard HD pixel density. GIGABYTE motherboards provide native 4K support with integrated AMD Radeon® Graphics via HDMI.
I was going to wing it with onboard graphics for a while but looks like I'll have to stump up sooner rather than later. Oh well.
There is no iGFX on Ryzen chips.
Motherboards can have display outputs but the CPU determines if they actually work; some motherboards even don't support the iGFX on certain CPUs!
It will have the video outputs for when the APU based Ryzen chips arrive which will have a builtin GFX core.
