What's up with high-end PSU stock availability?
11 May 2004
I'm trying to buy a >1000W PSU for a machine I'm building and all the brands I know and trust are out of stock with Overclockers and the competitors I've looked at.
What's up with the PSU market at the moment? Is it the resurgence of home coin mining, or is something else going on?
OP
11 May 2004
Do you actually need that much power though? What does it need to power?
Overclocked 1700X, two 1080 Ti, M.2 drive, 2 SSD, 3 HDD, 14 140mm fans, 2 D5 pumps, Aquaero 5XT.
It's mostly a ridiculous vanity project, but I'll also be using it for some work with CUDA that'll make the 1080s run at 100% GPU load, 250W for up to 8-24 hours at a time.
Man of Honour
12 Jul 2005
Aberlour, NE Scotland
A good 850w psu should be more than enough unless you are going to have both gpu's heavily clocked and overvolted. The one 1080ti SLI review that I can find used a X99 system with a overclocked i7 6850k and max power draw came in at 656w at the wall.
OP
11 May 2004
Thanks, that's very interesting.
I tried a couple of online PSU calculators, and both estimated something around 1000W. The two 1080Ti should take a total of 500W, so I was wondering where the other 500W was going.
6 Jun 2008
Finland
Single factory overclocked 1080 Ti can consume towards 300W.
https://www.techpowerup.com/reviews/ASUS/GTX_1080_Ti_Strix_OC/27.html
So depending how well SLI works and is capable to stressing both cards fully power draw can definitely be quite heavy for 850W PSU if you overclock CPU as far as it goes.
And in milliseconds scale graphic cards can draw considerably more.
http://www.tomshardware.com/reviews/evga-gtx-1080-ti-ftw3-gaming,5061-5.html
http://www.tomshardware.com/reviews/aorus-gtx-1080-ti-xtreme-edition,5054-4.html
