Spec my friend a 4x4
22 Nov 2006
LPG costs peanuts though, I don't think theres any tax on it. You can run a V8 on it pretty cheaply, but the tank will pretty much full up the boot.
21 Jul 2008
I had a 100L tank in the spare wheel well. Could fill it to about 72L, which meant a range of around 200 miles. You loose some mpg when running on LPG compared to Petrol (13mpg vs 17mpg on my V8 Range Rovers). The difference in cost is almost 1/2 price, when compared to diesel, usually around here anyway. What I found was that running a V8 Range Rover on LPG meant the fuel costs were probably similar to that of a Diesel Range Rover. Which in itself isn't exactly a cheap thing to run. So you can run a V8 Range Rover relatively cheaply, for what it is, V8 power for diesel fuel costs, but it is hardly cheap.
The cheaper way to fuel a Range Rover would have been to run an older diesel with a veg oil mix, being that you can pick up 20L of veg oil for around £16 or so, and still get circa 25 mpg. You CAN run straight VGO in the summer months, but probably better to run a blend with diesel in the winter months, unless you invest in heated fuel lines etc... But then who wants an old P38 or older Range Rover nowadays (apart from me).
Can't believe no one suggested the Fiat Panda 4x4 :rolleyes:
Diddums did suggest the newer 500 4x4.
18 Oct 2002
Darwin, Australia
If a Landcruiser is too pricey then a Prado would probably fit the bill.
The problem with the likes of Subaru/FIAT is that they dont have the ground clearance that a true 4by has. It really depends on the application. If its just gravel/muddy roads and fields then a saloon car may work fine. Proper 4bys have more options when it comes to all terrain/mud terrain tyres, Diff lockers, snorkel and after market suspension. That suits more serious applications that involve rutted/corrugated roads and rivers.
21 Jul 2008
A friend is after a big 4x4 that will carry him, his wife, his 2 kids, a pram and some golf clubs comfortably.
Doesn't really sound like diff locks, snorkles and all terrain tyres were really a consideration. It's for kids and golf clubs.
