Powershell experts critique this command please
18 May 2010
Hi,
I'm not the best with PS and I've pieced this together by googling, I need to know I've done it right as the result is unexpected. If you ran this command what would you expect it to do please?
get-mailbox -resultsize unlimited | Search-Mailbox -SearchQuery "to:***@***.com AND from:***@***.com" -EstimateResultOnly | select displayname,resultitemscount | Export-Csv c:\scripts\Results.csv
Thanks
Hi,
Thanks
Get All results from mail server that have emails to: [email protected] [email protected], showing the displayname & count them into into a CSV
So CSV would look like
Email Count
[email protected] 40
[email protected] 50
so on..
Email Count
so on..
Yes correct thanks for confirming, you missed that it should be To and From the mail address and I figured out why it wasn't working without throwing an error, it should be "Or" not "And" its working fine now and have the results I need
Cheers
Cheers
no problem, PS can be fun & also horrid at the same time.
