- 15 Feb 2015
This isn't an area of the forums that I frequent often but I could really do with some recommendations on how to go about reducing noise with my system.
Ambient noise is approx 35 decibels (measured using smartphone app. calibrated in a quiet room - still not sure how accurate this is)
I'm using an Enthoo Primo with ASUS x99-E WS motherboard plus 5820 and MSI 980Ti.
For cooling I'm using Swiftech H240-X along with 5 Phanteks PH-F140SP supplied with the case.
Fans are configured as follows
One on the rear near top blowing air out
2 on the bottom and 2 on the front of the case pulling air in.
https://preview.~ibb.co~/ep8DAQ/IMAG0707.jpg
All fans are connected to the supplied phanteks fan controller which is in turn connected to the CPU_FAN connector on the mobo.
Temps are all good (CPU is 30C at idle and 50C on stress test) and gfx card 40C at idle.
I used to have Asus AI Suite which allowed me some control over the fans but had to uninstall as it made the system unstable (flakey asus software!)
Currently not using any fan profile - profiles under bios don't seem to make any difference - also noise doesn't appear to increase under load.
Speedfan is saying the CPU fan's doing around 1850rpm - still trying to work out if I can control with speedfan somehow...
Not overly impressed with bundled fan controller - may just be user error but regardless but I've just not had much luck getting the case fans under control - tried all sorts of different setting - tried connecting the controller to CPU_OPT.
Would be really keen on getting peoples thoughts on discrete fan controllers (aquaero or similar) and recommendations on some decent quiet case fans or other suggestions
Thanks,
SV
Thanks,
SV
