So bit of a non update but still figured worth giving a little update on how I'm getting on with it.
Last tank of fuel it did 21.5mpg which I'm pretty happy with overall given my commute is B roads mostly
Hopefully it'll be even better with the manifold fixed. That tank included a mway run or two though, normal commute it does about 18mpg.
The heat reflective material from underneath the IC has all come apart and basically looks older than the car
So picked up some Nimbus G2 heatshield sheeting to go underneath the IC (which is directly above the rear turbo!) - will need to take the IC box apart to fit though which I'm not looking forward to.
Also I need to replace the front manifold with the spare I've got, moving house in 2-3 weeks though and can't risk the car being off the road (or worse, stuck at the current house) so will swap that afterwards.
In order to take the car off the road for repairs and not worry about rushing stuff back together relying on the car for work etc, I've bought a BMW 325ci (e46) which I'm picking up tonight
Plan is to still daily the Noble most of the time except for really bad days and winter when at the very least I need to take the Noble off the road to replace all the floor
Apologies for the somewhat crap update (bar the fact I did over 20mpg!) hopefully have some more interesting stuff soon
Will get some more pics of the car up soon too, infact need to investigate aftermarket exhausts as that supposedly is the biggest single bottleneck of the engine.
Looking forward to moving house as I'll have a nice big double garage to do all my work in. Step 1 is fitting a whiteboard (must find one...) to the wall and getting a to-do list together
