I couldnt class Prey as fun I've spent the last 2 hours dying over and over from the black monsters who have super health ! FPS is meant to keep you wanting more I'd avoid prey.
+1 to this with the caveat that it's horribly optimised for a lot of setups.
Scratch that, it's unplayable on a lot of setups. Unless you delve into the config file and hope it saves (which is 50/50) the configuration, you might be **** out of luck. If it doesn't work, at least you've got steam refunds though.
For my own input, Titanfall 2's SP campaign is excellent! It came to the EA vault this month, and it's well worth it.
