so today I noticed my cpu was a wee bit hotter than normal..
time to dust was my thoughts..
so stripped everything down and gave it all a clean and it wasnt that bad..
so rebuilt it and botted the system up with the side off it!! no movement from the cpu fans!! so a little bit of investigation and the fans are running but only at full speed!! the little pwm lead has decided to let go.
so my thoughts are 2 good PWM fans are now required!!
Ideally I would like red/black as this would go with my hardware better..
https://www.overclockers.co.uk/phanteks-ph-tc14pe-cpu-cooler-red-hs-002-pt.html
looking at these.. thoughts
b]My basket at Overclockers UK:[/b]
Total: £15.72
(includes shipping: £2.74)
Total: £15.72
. But yes they are as quiet at the same speed. I normally disable pwm and just run them at full speed so that's why the t143 is louder for me
also they do shift a lot of air at full speed nearly as much as my deltas, but at half the ram.
