- 14 Apr 2014
- East Sussex
Hi Guys
The file server I've been using for what feels like forever has just died and I need to get something up and running ASAP, I dont have a great budget to work with right now - but do need to consider future expandability, requirements are:
- Expandable (Mobo below has plenty of options in this regard)
- At least 4 TB of storage
- ECC Memory (thinking about changing below selection to 1x16GB stick so I could get to 64GB in system further down the line.)
- I'll be using Linux with OpenZFS
- Drives below will be Raid 1
I'm thinking about going for this setup:
2 x 4TB Toshiba N300, 3.5", SATA III - 6Gb/s, 7200rpm, 128MB Cache
1 x ASRock AB350 Pro4, AMD B350, S AM4, DDR4, SATA3, M.2 (PCIe/SATA), Realtek LAN, USB 3.0 A+C, ATX
1 x AMD Athlon X4950, S AM4, Quad Core, 4 Thread, 3.5GHz, 3.8GHz Turbo, 2MB Cache, 65W
2 x 8GB Crucial DDR4 Server Memory, PC4-19200 (2400), ECC, Unbuffered, CL 17, 1.2V
The above will be added to some stuff I have on the shelf:
-Intel PCIE dual Gigabit NIC
-2.5" SATA3 SSD boot drive (60GB)
-Antec 650W TruePower PSU
-Antec Midi Tower (6x3.5")
+ the lowest powered video card I can find in the house.
Any serious issues with the above spec? Would 16GB of ram be overkill? Server will be running a couple of smb / nfs shares, nginx (low load), prometheus (lowish load) + a tiny elastic search index.
I can do the above for £466 delivered with 8GB of memory, will be about another £60 to make it 16GB.
Is this mad - should I be looking at something else? I like this option as with a full ATX board I can add a better SATA controller, or a 1TB of Nvme, or 10GB ethernet etc etc, as and when I choose (or even a better AM4 chip once prices comedown).
Most of the Dell/HP/Lenovo stuff I've been looking at (cheap servers) are severly limited in the expandability department, lots of propriaty form factors (mobo/psu/case), limited drive expandability, not a lot of PCIE slots, and unsurprisingly ECC is not shipped in a lot of basic servers (though many support it).
Any advice appreciated! Dont really want to spend more than around £500ish
Ta
Ta
