I want to try something out to see how it looks, so here it goes....
"AMD have the most powerful and most power efficient CPU on earth right now"
Yeah, feels good![]()
I have some of these higher core count Intels running fine in current boards.
Just to add to this the R&D budget was also used for developing the consoles as well.I think you need some quantifiers in there,
"AMD have the most powerful and most power efficient CPU on earth right now...... and they are using an inferior process and have an R&D spend that was around 1/12th of Intel's in the last quarter.... and spend a decent wedge of that on GPUs as well".
I said earlier, Intel should be flat out embarrassed. Even if AMD had a one generation ahead process that R&D spend difference should mean AMD struggle to make something half as fast. AMD created a single die that whips Intel across three different platforms(server, hedt and mainstream) despite all the difficulty that brings. Intel has the money to tape out 20 times as many chips as AMD yet somehow making specialised server chips have something with less cores, uses more power, has less performance(in many many situations and this is with extremely little optimisation with AMD architecture and 100% optimised for Intel) and significantly worse I/O.
If AMD spent the same 3.26billion on R&D in the last quarter that Intel did, instead of the 279million they did, I'd still say wow for beating Intel on a worse process. But to do it on that big a difference in spending, it's literally amazing work by AMD and again nothing short of horrifically embarrassing for Intel.
This is a true Xerox moment, where Intel decided to put marketing and business people in charge rather than engineers, spent years spending extremely poorly. I mean AMD spend on their entire Zen project is dramatically less than Intel spent just on their attempts to get into mobile strongly and they've utterly failed where as AMD have taken the fight and surpassed Intel in Intel's core business.
R&D changes over time but since late 2012 AMD's highest R&D spend in a quarter has been 328mil, Intel's lowest in the same period was a little over 2.5billion. The thing is Intel aren't in THAT many more areas than AMD and a lot of the areas they get into they often just buy companies to get their tech. Mobile with Atom, complete failure and they spend literally billions buying sales to prop up the numbers. Network cards, sure, and good, but the expense there is tiny, modems(as in mobile phone) they spend on but again we're talking a pretty small amount of money there. Intel's fundamental business is CPUs, you could say SSDs as well which is fair but still fairly small costs as the bulk of R&D there comes from micron and partners same way AMD work heavily with companies on memory but the bulk of the spending comes from the memory partners.
Nice.Actually I think we have 2 7900X capable of running 5ghz 24-7 but these will be held for benching and 8Pack systems.
When I say higher core count I mean 12-18 Core Skylake E cpu's..in hand and ready to rock!!
New 8Pack Xtreme Team Group signature series mems in stock now mem testing the 4133mhz at 4433mhz at the moment.
On which platforms?
X299 Asrock OCF
Mobile with Atom
On Skylake X IMC is limiting factor not mems. Even 4100mhz can be difficult on Skylake X
