Hi all, i got a seat leon st with 1.2L engine. While it is decent enough i feel the brake can do with an upgrade. This is especially the case when the car is loaded up. Definitely some hair raising moments...Any recommendation for casual road use pads that are better than OE ones (mainly for cold bite)? I used to have EBC greenstuff for my 2004 astra and that does pretty good job when it was cold. I generally drive quite slowly for mpg reason. Im trying to see if there are alternatives. I can see some brembo pads that arent too expensive on GSF but dont know if it will give me the upgrade im after.
(Front tyres are P7 and rear is bluresponse at the moment. May switch to crossclimate when it gets colder)
Thanks.
Thanks.
