Without knowing it's full spec it's hard to recommend what to try retrofitting/upgrading/adding!
Yeah I have the official boot liner in my Golf , very nice foamy material and easy to clean and also doesn't allow items to slip around when stuff is on it. Got it for £15 down my local dealer
LED interior lights, front/rear lights (except headlights) if you fancy it.
Car mats are a must, bootliner as well perhaps if VW do one?
enjoy! post a few more after the cam has been installed.
I can't see from the pics but I think I would have the rear side and main rear window tinted![]()
I like the idea of LED interior lights, where would I go to get something like that done, and how much roughly would it be?
What tint would look good? I'n not sure if it is tinted already, I don't think it is, I will check tomorrow.![]()
Well the car is dark, so I would say a light tint, not drug dealer limo black but a lighter tint that would compliment the car.
Also, just because it's tech, but I would either replace the rear view mirror with a dimming one (if it hasn't got one) and wire in a reverse camera to the mirror. I did on an old 4x4 we have because my 2014 VW Amarok has one built in (it has an RNS315) and it's great. The one I wired in was cheap as chips, about £30 for the mirror and cam with all fittings and wiring from eBay.
Other things I would do is:
1) if it's got a space saver, get a full size spare
2) does it have fold in mirrors? If not, I'd check the wiring loom and see if the plug is present, if so get the switch and replacement mirror motors from eBay. It's such a small thing but I love the mirrors that fold in on my Amarok!
Much rather have a full size spare, allows you to get on with your day and change/repair the flat at your convenience, rather than effectively being forced to limp to the nearest tyre shop and hope they've got something in that's suitable and not a rip off. Nothing to do with aesthetics, everything to do with being able to carry on as normal.Not sure why you would want a full size spare as the space saver is more than adequate to get you to a tyre fitter anywhere in the UK. It is purely aesthetics and you loose the low level boot height fitting one in there. Better spending money on other things you are going to use uistead of a just in case item IMO.
i have one in my car for the same reason , that and if not it would be a can of that repair gel kit thingMuch rather have a full size spare, allows you to get on with your day and change/repair the flat at your convenience, rather than effectively being forced to limp to the nearest tyre shop and hope they've got something in that's suitable and not a rip off. Nothing to do with aesthetics, everything to do with being able to carry on as normal.
