Wiring smoke alarm
7 Nov 2005
Widnes
Hi guys,
When I moved in I installed two Nest Protect smoke alarms. The guide was easy and I put the wires where told. Now I need to remove them and, while I took photos of the downstairs wiring (Brown - Live, Black - IC, Grey - Neutral), I didn't for the upstairs smoke alarm.
Does anyone have any suggestions?
The obvious one is green/yellow = Earth. I think black is the IC like downstairs but why are there two live and what is blue?
Smoke alarms are usually wired...
First alarm will have 1 x twin and earth + 1 x 3 core
other alarms will have 2 x 3 core
final alarm will have 1 x 3 core
Twin and earth is supplying the power to the alarms and the 3 core is then passing the power along to all other alarms plus the extra core for the interlink to make all alarms go off at the same time etc
looks like you just have 2 alarms
you just need to put....
First alarm
2 browns in live
blue and grey into neutral
black in to ic
2 earths in earth terminal
If you had other alarms 2-x you would...
2 browns into live
2 grey into neutral
2 black into ic
2 earth to earth
And final alarm
1 brown
1 grey
1 black
1 earth
etc
How much time did you spend swearing trying to get solid core wire bent into the terminals correctly? :p
I installed some of those AICO alarms around my house a few months back using 1.5mm solid core wire - what a pain!
The worst bit was trying to get the terminal blocks off the old Nest setup. I gave up and cut the wires in the end.
Push fit on the new ones. Shame the wire they give you is so short. I just connect mine off the lighting ring.
I don't get dedicated alarm rings. I'm doing the exact same cause in my eye wiring into 3 separate lighting circuits is better than a single fire alarm circuit!
Got my new nest protect sitting here, can't wait to fit it.
They are normally on the same circuit because they are hard wired with the IC, one goes off they all go off.
That link is starting to become more commonly wireless though.
