Well your location says Monaco. If you are actually in the UK & know you won't wear it again you could hire it. If you are in Monaco I haven't a clue.Hi chaps, I need a 2 piece suit for daughters graduation, I'm not really a suit man and obviously don't like spending money on such things.
What's the best approach?
Thanks in advance
And synthetically sinful! Look at that stretch! Might as well punch through the bottom of the barrel and go full Primark.ASDA for cheap and cheerful.![]()
Yeah I've bought a couple from here and they are always super helpful and the suits seem decentI recommend Slaters if there's one close to you. Great service and all sorts of suits to fit different budgets.
Slaters all the way mainly because they offer free alterations and even a cheap suit well fitted will look better than something 10x the price which isn't quite the right fit.
If the tailor does not come to you, there's still doubt.Saville row. Anything else is for paupers.
Best approach
Go to shop, pick and buy suit within budget...
