can I install an m2 SSD with 5x hard drives?
20 Oct 2002
Oxfordshire / Bucks
I am currently looking at my manual, but I dont quite understand in storage part
I have a MSI Z170A Gaming Pro and I am considering buying an m2 SSD (assuming its faster than a normal SSD?)
and i want to know if it will work along side 1x SSD and 4x HDDs
(6 drives altogether)
thanks
According the manual that mobo will disable sata ports 5-6 if an M.2 drive is installed and it only supports a 'PCIe' M.2 drive. So that will limit you to 5 drives in total.
You might want to check for bios updates.
Andi.
Most motherboard share m.2 lanes with SATA lanes, so if you consume 1 it'll disable parts of the other, as Andi has said.
I think actually some it depends on the settings chosen, recall something in my old Asus board only disabling when set to Sata Express which is not required so have a check of that. If you really want all of them then consider getting the hyperkit for about £15 and mount the M2 in that to take from the PCI lanes.
Possibly but on my Z270 board, it has 3 PCIEx4/SATA3 slots, if all are in use then certain normal SATA ports are disabled (and vice versa), this has been the case for all my systems for the past 2 years as that's as long as I've M.2 capability!
thanks guys
ill have to read up a bit more, but am i right in saying that the m.2 SSD slot has its own slot, but takes some of the PCIE bandwidth ?
thanks guys
It depends on the m.2 SSD as SATA m.2 SSDs will take away one or more (according to the specs on the MSI website SATA ports 5 and 6 will be disabled) standard SATA ports while an NVMe m.2 SSD will either share bandwidth with a specific PCIe slot or have its own dedicated PCIe bandwidth and there's nothing in the specifications that states that there's any PCIe bandwidth sharing with the m.2 slot with a PCIe/NVMe SSD.
