I3-7100 vs R3-1200?
Yes she's an accountant so mainly Excel. Some fairly big Excel.
I just realised that Ryzen is a true 4 core whereas the i3 is a hyperthreaded dual core. So a no brainier I guess.
Oh, and this might be a total noob question but Ryzen being a "CPU" and not an "APU" I still assume I don't need a GPU for this build to function? Ryzen still has some basic onboard graphics yeah?
Ask her to show some time-consuming operations in Excel, and check task manager how many CPU cores it uses. I bet most of the time it's single-threaded. In such case, go for the i3 with higher frequency, as well as a free integrated GPU.
She hasn't started yet. This will be for her arrival. I think you might be right, what with having to buy a GPU too... Shame, I was slightly excited about buying Ryzen.
Yeah... I built an ITX before (Intel i7-7700T 35W TDP) and was thinking about a similar approach but didn't realise that budget can be exceeded so easily...
You can save ~£23 with a G4600. Still 2c/4t but at 3.6GHz. You lose 300MHz, AVX and 1MB of cache down to 3MB.
Yeah I think Intel makes most sense here due to the integrated GPU. Like realistically we're talking about spreadsheets.....even a G4560 could be overkill, but I don't think a Kabylake i3 is needed.
Kolink PSU's are relatively OK for their price.
They are still available! Some reason I was under the impression they were EOL. If they are, def go with the G4560. Will bring your build to ~£290.
Hiya, for Office work i'd get a very good silent PSU !
The EVGA 430W that my Brother has is super noisy for about 20 minutes after start up, very distracting if you are trying to work.
Suggest asking in PSU section for a good recommendation.
Alternatively, buy a 2 year old Dell/HP SFF system from an auction or clearance site for about £120. I just got 3x Dell Optiplex systems with i5 3470, 8GB RAM, 320GB hard drives for £89 each, the HDD's have been replaced with SSD's and they also had legit OS, Windows 7, with upgrades to Windows 10. Oh, they are pretty much silent too, so bonus. :)
Seeing how long office PCs get used for (I bet 5+ years), I'd go 4C/8T at a minimum. Also plenty of memory.
Yes it is better to buy cheaper systems more frequently, but it never works out that way.
It's not a major expense in the grand scheme of things compared to salaries and you won't get a frustrated employee.
