How to set up second monitor
28 Jan 2011
Hey guys,
I have just received my two new monitors which I have set up just now..
The problem im having on W10 is setting up the second monitor to be used as a setup for "extra work space"..
Currently it is set that everything I open on either monitor opens the selected program on monitor one, and I cannot say..drag a Google Chrome window to the second monitor and maximise it to display on the second display..
Sorry about my description, its just hard to try and explain what I mean..
Any help greatly appreciated guys? Or is there any programs I can DL to setup the multiple displays?
Cheers!
Hey guys,
Got it sorted, downloaded some software..incase anyone is after software for more options on multiple displays its "DisplayFusion"
Are you saying you want to maximise applications across both monitors as if they were one panel? So like, a 3840 x 1080 Chrome window?
No mate, I basically wanted them to act as two separate monitors, but I was having trouble getting the apps to cross monitor, the second display kept using the main display when opening and using apps :confused:
