Did they really service my car?
I am sure they do always check, as some others may do , but the point I am making is that they don't have to, and it is most likely as a courtesy, due to that particular garages policy.
Then your point is taken and acknowledged.
Maybe they read the bit about "when it is noticed that there is a defective tyre" and took it to mean when, not if, suggesting they were supposed to check as a matter of course even if they don't test and record their findings, and so do this for all cars.
In fact I would not be surprised that maybe one tester does the check, and another tester at the same garage on a different day, will not, as he never checks any when he does a test.
Ours only has the one tester and they always check.
The only check necessary on an externally fitted spare wheel or spare wheel carrier is that "it must not be so insecure that it is likely to fall off".
Which I assume isn't so easy to tell if the carrier is loose, or the wheel just isn't nipped up enough.
To conduct this test, there is zero need to remove anything, and nothing should ever be removed.
Well I'm not gonna report this one to the authorities just yet... They're the sort who will, if you ask, correctly adjust the headlights rather than outright fail them for being slightly out. Doesn't even need to remove anything, so everyone's happy.
If an inspector (like myself) should ever come along, and see anyone removing anything during a test, then the relevant tester and testing house, will get, at the minimum, a written warning from DVSA, or possibly loose their license, if they have had previous warnings, basically two strikes and you are out.
Sounds like a popular job role...
I agree that some items should be notified to the presenter, but I also think there are occasions when too much info is given to the presenter, and some of that (MOT advisories included) could be looked at as a revenue generating move, rather than as a real information giving move.
With MOT advisories in general there is a lot of room for improvement to the current system.
Firstly you need to remember that advisory notices are a non-mandatory part of the MOT and it’s up to the individual tester to decide whether to advise on an item or not, I know many testers who will never issue any advisories.
If they are issued then the advisory must be useful to the vehicle owner for keeping their vehicle roadworthy, or to clarify a significant aspect of the vehicle, such as a missing passenger seat.
It’s important to remember that inappropriate advisories can reduce the resale value of a vehicle or result in unnecessary repair work, that can be seen as a revenue stream for the garage and could come across as money making, rather than purely informative.
Evidence shows that in many cases testable advisories have become overused, sometimes with the same advisory being used year after year.
We may be partly responsible for this due to the wording of some advisories; such as a component ‘slightly worn’ or ‘slightly corroded’, when they could be in perfectly usable condition and the corrosion or wear has zero to do with the items functionality.
Also it has to be considered that when a customer is presented with a list of advisories, most often the first questions are " how important are the items to be repaired?" "How much to repair this lot?"
When assessing worn or corroded items you should, before issuing an advisory for a ‘slightly’ worn or ‘slightly’ corroded component, consider whether it meets the guidance in the Manual; eg, "is near to, but has not yet reached the point of test failure".
If it is likely to reach the point of being a test failure item, before the next MOT (this point being well before actual item failure making vehicle dangerous of course) then put it as an advisory, if it will last a couple of years then it is not worth mentioning really.
Similarly, consider whether it is necessary to select items from the non-component advisory list such as “undertray's fitted obscuring some underside components” where they are known to be standard fitment on the model of vehicle tested, that kind of advisory is completely unnecessary in reality.
As part of MOT modernisation and the new EU directive we are currently reviewing advisories and their wording, and in fact reviewing the whole concept of advisories.
In theory, yes.
But the presenter is just being advised and they're free to ignore it (as happens so often) or get it sorted elsewhere.
Working in a similar capacity myself with a similar conditional assessment framework, albeit with very different assets, it is a highly subjective assessment as to whether something will fail or not, especially when it can be subjected to a variety of different uses and conditions that cannot be foreseen - A single spur-of-the-moment trip through the potholes of Redhill one day, when a driver usually just commutes a few miles, can have a profound effect on a vehicle...
It's probably just an ass-covering exercise - You spot it, you note it.
Again, just covering their backsides.
If you're at all worried about an MOT tester angling for work then take your car to the local council MOT depot. They don't do repairs and you'll need to book but they have to allow testing of private vehicles too
Similar to that, there's a very well regarded MOT centre a couple of miles from me that I use, they don't do any repairs and they don't have a "mate" down the road they recommend for work that does need doing, so I always bring my cars to them.
The current car I have has had multiple advisories in the past for 'plastic undertray fitted', which I just find as pointless, these guys don't add daft things like that.
Best advisory ever:
It is indeed diesel. I'm only doing 3K-4K miles per year.
They measured the depth of tread on the spare tyre, which is in the boot. And I've routinely found that the rear-view mirror needed re-adjusting. Indeed, surely they would have had to have had the RVM set correctly for the driver to reverse into the parking pitch?
I agree, but you never know.
i don't touch mirrors but I would put your parcel self back or at least try to
There's one of these right round the corner from where I work and I've thought about trying it. But I was worried that they would be stricter than the back street place I use.
I had never ending problems with the council place when I took my car to them. Failed it on so many stupid little things. Took it to 2 other garages, one kwikfit and one local indie and both said half the issues they flagged up were nonsense. Ended up just telling kwikfit to re-mot it and it passed with 0 advisories.
