The RX Vega 64 Owners Thread
He said to disable vrm monitoring in HWINFO, I'd just told him what I had tried with so I presumed he was saying to install that and disable it through that. Why would he then tell me to disable such and such if it isn't one of the programs I had just told him I was using?
I've uninstalled it now anyway.
N
Any pump whine on the AIOs like the FuryX ?
No pump whine here, I've investigated a bit more on my end and can confirm that it is the fan that is a bit noisy (it's more it's acoustic signature I don't like).
Would be interested to see how easy/hard it would be to replace.
EDIT: I'm talking about noise while under load, on idle it's near silent to my ears.
Anyone care to post what temps under load the AIO cards reach.
60 running the ROTR benchmark.
64 when running the Furmark burn in at 2560x1440 - it really didn't like that though - started to throttle although I don't know if it was because of the card temp or CPU - more likely the CPU I guess.
https://www.techpowerup.com/236205/...o-ati-rx-vega-and-the-nexxxos-gpx-for-rx-vega
Quite a bit different looking. As someone said, industrial.
Nothing here. Like mentioned the fans a little louder than any other fans I'm using but not by much.
Thats good to hear :)
For the OP Kaap. :)
1x Sapphire RX Vega 64 Water
One of the best looking GPUs I've ever had, and it feels lovely to the touch, too. :p
Excuse the cables, i quickly pulled out the Pro Duo's to have test.
Drool. Best looking GPU ever in my opinion. Enjoy mate :)
:D
So, been playing around this morning looking at what the default Wattman profiles actually give us with standard Vega 64. That would be Power Saver, Balanced and Turbo. Just to see the difference in the clocks, temps and the amount of watts going to the wall socket. Got a small breakdown here if anyone interested. I don't understand why AMD recommend a 1000w PSU, absolutely bonkers if you ask me.
There's going to be a bit of randomness in the numbers, not sure all the sensors are reporting exacts at the moment, but I believe GPUz is to be trusted the most.
Power Saver (-25% power limit)
GPUz Core - 1200mhz (rough average)
Temp - 68c
Fan Speed - 2000rpm
Balanced (0% power limit)
GPUz Core - 1536mhz (rough average)
Temp - 78c
Fan Speed - 2400rpm
Turbo (+50% power limit)
GPUz Core - 1630mhz (rough average, did start to throttle at 85c)
Temp - 85c
Fan Speed - 2430rpm
How many of these wall socket devices have you got?
Any owner of the Liquid Edition who like me is not impressed by the fan on the radiator? Pretty disappointed sound wise, does anyone know if it's an easy swap?
Can't say I've noticed the noise myself - the only thing bothering my with the card is that they put the tubing on the front of it - as I keep banging on about - but I mean who thought that was the best place for it?
No pump whine here either.
Much obliged to you kind sir.
Sad to report that i believe my first Vega GPU is faulty, crashing at stock in different games and benches. Ordered a second and will be here tomorrow, so should be able to confirm if the first is indeed faulty.
This weekend i will be building a threadripper system, so hope to have plenty of benchmarks and videos up before long.
where do i find that matt? cant seem to see it. Can you post a pic please.
Are you using the latest build of HWINFO64? Believe it's 5.56 xx something.
It's listed as Vega xxxxxx VRM so you should not be able to miss it Tony.
I can't provide a screenshot right now, but can do tomorrow if you need it.
yeah thats the version i have. Would it be this?
