- 12 May 2011
- Southampton
I want to connect my Dreamcast to the internet. The easy way of doing this to get a connect your Dreamcast to a Raspberry Pi which has software pretending to be a phone line, or something, and this it allows you to connect your 56k modem Dreamcast to the internet using your normal broadband as the Dreamcast thinks it's just connecting like normal. I have 2 of the 4 bits of kit already and will soon order a USB modem and voltage inducer.
However, I hear you can also just connect it up to a dial-up connection if you still have one of those.
I have found various dodgy looking 'free' dial up services, which, for the cost of a 0844 call connects you to the net. So first of all, has anyone used these? I can't see any hidden costs, like a £5 connection charge or anything but I am still a bit nervous...
Secondly, I have virgin fibre broadband and the basic phone package. I don't have the virgin phone though, I probably have it on my package as it was impossible to deselect it. The Virgin fibre connects to 'the outside' through it's own connection on the wall, not the BT phone socket because it is fibre not ADSL.
So this means I currently have a BT phone line in the lounge which is not in use. Can I still use this for my dial-up experiments, or will Virgin have figuratively and/or literally cut off this connection?
Obviously the easiest way to try is to just plug a BT phone in and call someone, but I don't have one!
