Install and use 32bit app on Win10 64?
18 May 2010
Hi,
I cannot install a Legacy app to Win10 64, I know it installs and works fine on Win10 32.
The problem is I need to run this app on a tablet with a SIM slot and Win10 32bit Tablets with SIM Slots simply don't exist.
I have all the usual stuff to get it to install, compatibility mode, developer (Side loading) but no joy
Anyone know of any software or anything that gets around this issue? Or better still where I can find a Win10 32BIT Tablet with SIM Slots!
Cheers
Is it actually 32bit or is it 16bit?
32bit should work, 16bit won't at all iirc.
It might just be a 16-bit installer too, which doesn't help.
Yea 32bit windows includes NTVDM which I believe is what is required to run 16bit apps, 64bit doesn't have that so will just flat out fail.
Sounds like whats happening. Looks like I need to buy a 64 bit Windows Home tablet, an additional license for Windows Pro 64 just so I can legally install a 32BIT version of Windows and that's if the device even lets me install it!
You can get a 90 day trial of Windows 10 enterprise which has a 32 bit version. And I am fairly sure that a license for windows 10 home or pro covers both the 32 and 64 bit versions.
No, you preferably want an OS that didn't have activation like Win 95, 98, NT or 2000. Plus those early ones are less resource intensive.
But you also want to secure it from network access, as ancient operating systems installed from CD/dodgy iso are likely to be holed by some nasty or another in minutes online :p
Because you cant install Windows 10 Enterprise directly from Home.
Home > Pro > Enterprise
You can install it directly from the iso. However 32 bit home windows should work on the oem license. If it doesn't, unlicensed windows still works quite well.
You might be able to use WINE on Linux if you want a secure OS that is free and can run some Windows software. Not sure if it works with 16 bit apps or not though.
Edit: Hyper-V runs Linux just fine.
