- 29 Jun 2004
How do these cars pass their yearly MOTs without failing emissions tests? How are they road legal?
It's a mot fail if the exhaust has been changed to make it louder - but this is so vague that it's generally not enforced unless the MOT tester is having a bad day. I could imagine someone arguing that without dB readings of a stock car (and some tolerance range) there's no quantifiable benchmark to test against, so there's no actual "proof" it's louder...
It's also a MOT fail to remove any cat, a lot of modern cars have 2 cats and modders tend to remove the 1st when changing their headers and the rear with a simple straight pipe section, or when changing to a stainless steel exhaust. But, the mot test for removed cats is a visual one, so they just look for a bulging bit in the exhaust (which could simply be empty inside) Without knowing every model of car, how are they meant to know the car should have 2 instead of 1? It's time and effort to go looking for cats, so why bother? I think that the present emissions can usually be passed with only 1 in place, especially if it's been warmed up first. But, with a friendly backstreet mot test station, they can test a different car if their palms have been greased, and you still get a pass... Emission testing if open to abuse, but they can't test against "stock" or book values expected for a stock version of that model car, as VW has recently shown, the book/estimated values for emissions can be wildly different to real world.
good point about the plastic undertrays with more and more performance cars.That and the whole underside is covered by under-trays, which they won't remove anyway.
If it still has main cat(s) and it passes emissions then where is the issue?
while yes, I agree in some respects, but surely the car manufacturer didn't just spend money on the parts and fitting of that pre-cat for shirts* and giggles, and is required, in their eyes, to meet certain emission targets?If it still has main cat(s) and it passes emissions then where is the issue?
I don't think the 2nd cat is even monitored with sensors most of the time, it isn't on my car. You can pull it out and the ECU doesn't notice.
Someone did a test before and after removing one of the cats and it made practically no noticeable difference to the emissions. There's going to be huge diminishing returns after the first cat. Maybe 2 cats are a requirement in some markets, but it cheaper just to slap them on all their cars than make different sets of manifolds or front pipes.
