I came about as a Fiji owner ~ Feb 16, I had been knee deep in Hawaii bios mod and enjoyed it. SomeOCN  Fiji owners were after bios mod, I gave pointers on OCN where I usually post. As this did not bare fruit I then got a Fury Tri-X. I picked this as it was on promo at the time and I also wanted to experience shader unlock.
I did gain 3840SP, I then also picked up a Fury X again on promo. In total I have had 1x Fury Tri-X, 8x Fury X and 2x Fury Nitro, info on these exploits is on OCN.
When I joined the Fiji owners club on OCN there were some highlighting that HBM clocks in steps. ie 500 / 545 / 600 and 666.
As I found no info I asked a member for source, I was then pointed to a post by AMD Matt on OCuk, I also found the same info on Guru3D posted by him.
I kept an open mind, I was a disbeliever initially. Using AIDA64 GPGPU bench it was clear that HBM did OC in steps. So then I iterated to as many members as I could the info.
Now for months, since v17.x.x drivers AMD have gimped HBM performance gain from HBM clock increase.
Here is a zip of today testing, link.
No single result on v17.8.1 has beat 1145 / 545 Memory Copy, I have in the past also done this testing on my i5 4690K at 4.9GHz CPU and 4.4GHz cache. Here is link of some testing back in May.
*** edit ***
I know this card very well I have done in the past 250+ 3DM 13 benches on this card besides the other hours and hours of usage for f@h, gaming, tweaking, etc.
This card on any driver below v17.8.1 can not do more than HBM 545MHz, it will artifact at desktop and look WOW on v17.8.1 I have had ~30min usage (compare clock in linked zip for screenie on 1145 700 with below link).
http://i.imgur.com/rGpDuew.jpg
*** edit ***
