- 21 Sep 2010
I bought an RX480 with 'water cooling' recently and this is what turned up:
http://imgur.com/a/1wnar
http://imgur.com/a/mVruH
This is not the kind of water block I was expecting, but rather looks a lot like a CPU block sort of bodged on there with some slightly wonky screws, and then the original RAM/VRM cooling plate from the reference model sawn off roughly where the PCB ends. My question is this: how likely is this cooling solution to be any use whatsoever? It'll be a short while before I have the other water cooling bits to test it, and I'm wondering if it's worth bothering at all.
