Forget about the tree huggers Humans are replaceable, it's the Polar Bears you need to be thinking aboutPower draw might be more interesting. The tree huggers will be up in arms!
Why didn't you post HW Info with that showing the Temps Ian ?
That would have been so much more interesting don't you think ?
Agree the Intel HEDT are too expensive. I think the whole xeon line up is.
I know you're trying to be smarmy with this one, but given cooling is subjective why would it be pertinent to do this? Or in actual fact, what would it prove. Heck, it's not like you could compare a TR CPU clocked similarly. Keep on that train, though, even a broken clock is right twice a day.
Is there a cooler on earth that can keep these Intel chips below 90c with an overclock?
1.8-1.9 is low volts for these?This Cpu is delided with only low voltage. So Temps not an issue.
Careful Hotwired, some peeps might think you are being "Smarmy" and you don't know how to tell the time![]()
Forget about the tree huggers Humans are replaceable, it's the Polar Bears you need to be thinking about![]()
thats input voltage. no way can you run that on the core. certainly not without LN21.8-1.9 is low volts for these?
