Crysis 2017 Mod compilation
27 Apr 2014
Included in the Crysis 2017 Mod compilation.What does a 2007 game look like with some mods.
(Bonus Textures and shaders will also work on Crysis Warhead.)
1.
a.Top 5 Time Of Day files with installers.
b.Better Textures/Objects with installers.
c.Improved shader files with installers.
Download- https://drive.google.com/file/d/1tBUB2-gIy0tFyuL8RCQUTZLM-BH6zEuX/view?usp=sharing
2.
Top 5 ,Time Of Day files with Stand alone installers.
Download- https://drive.google.com/open?id=0B273Qp8fBbjbSHVGNGdIY2tocWs
Read the read me in the download.
I take no credit for the mods.List of mods used in the read me.
Video Crysis 2017 Mod files used-if lights are to bright for you ,you can delete the shaders files in ZPatch2.pak and delete ZPatch3.pak
a.Installer RELI2ToD - RELI2 By Hawkeye Time Of Day Files Of Day Files
b.Install Flare HDR Normal -HDR Normal with Anamorphic Lens Flares(Blue) + WaterWaves + Improved Shaders
c.Install Textures - Updated Textures From Original
a.Installer BFMUTOD - BlackFire's Mod Ultimate Update 1.3 Time Of Day Files
Some Screen shots from different installers
Crysis_HDR_Bright_Lens_Flare
Crysis_HDR_Normal_Lens_Flare
Crysis_Mster_TOD
Crysis_Naturl_TOD
Crysis_No_Water_Wave_No_Flare
Crysis_Water_Wave_No_Flare
Crysis_BFMUTOD
Crysis_CCCTOD
Crysis_RELI2_To_D
Code:
[/COLOR][/FONT]
[COLOR=#ffffff][FONT=Open Sans]How to install.
1.Best results is to play in devmode.Also for Mods to work Correctly.
ADD(-devmode)to crysis target line in shortcut to game.
Looks like:Electronic Arts\Bin32\Crysis.exe" -devmode
2.Always Delete Shader Cache files before adding new Shader files to avoid errors.
(C:\Users\yourname\Documents\my games\Crysis\Shaders\Cache)
3.Unzip/extract all files to game folder
Electronic Arts\Crytek\Crysis
4.Click on the Installer You would like to try,your choices are.
a.Install Flare HDR Bright -HDR Brighter Than Normal HDR with Anamorphic Lens Flares(Blue) + WaterWaves + Improved Shaders
c.Install Textures - Updated Textures From Original(See List Below) + No Anamorphic Lens Flares + No WaterWaves + Improved Shaders
d.Install WaterWaves - No Anamorphic Lens Flares(Blue) + WaterWaves + Improved Shaders
e.Installer BFMUTOD - BlackFire's Mod Ultimate Update 1.3 Time Of Day Files
f.Installer CrysisTOD -Original Crysis Time Of Day Files
g.Installer CCCTOD - Cuban-Ultima-Doom-Assassin47-Taowolf-Sword's Custom Crysis Configs [CCC] [Triple "C" Pack] VERSION 2.21 Time Of Day Files
h.Installer MsterTOD - Mster Config v3.01 FINAL Time Of Day Files
i.Installer NaturlTOD - Natural Mod 2.0.2.Time Of Day Files
j.Installer RELI2ToD - RELI2 By Hawkeye Time Of Day Files
5.Uninstall Files
a.Uninstall Time Of Day Files- Click On Installer CrysisTOD.bat- (This will install Crysis default Time Of Day Files)
b.Uninstall Flare HDR Bright or Flare HDR Normal or WaterWaves -Delete ZPatch3.pak in this Folder(Electronic Arts\Crytek\Crysis\Games)
c.Unininstall Textures - Delete ZPatch2.pak(Electronic Arts\Crytek\Crysis\Games)
6.If you want to use any modded files for the Crysis game and use the installers just unzip your modded files(Looks like this EG:z_xxxx.pak) and overwrite the files in this folder ZPatch1
Thanks to all the modders.I take no credit,just put some files together for easy installing and easy sorting of your Crysis mods.
7.To load all weapons/cheats press` in game to open console and type exec autoexec.cfg
Bind keys are
bind 6 time_scale 0.3  - Slow down time
bind 7 time_scale 1    -Restore Time
bind 9 cl_hud 0        -Clear Hud
bind 0 cl_hud 1        -Restore Hud
bind 8 r_drawnearfov 2 -Change Field of view
bind i r_drawnearfov 1 -Restore Field of view
bind u ai_ignoreplayer 1 - Enemies ignore player
bind o r_depthoffield 2  -Depth of Field on
bind p r_depthoffield 0  -Depth of Field off
Included Mods full or part used.
AY-69
Ammo Boxes SXL & Radioactive-Container
Asian AAA Black skin
Asian APC amphibious camo desert skin
Asian APC camo desert skin
Asian Heli grey rusty skin
Asian Smallboat camo snow skin
Asian Truck red used look skin
Bow & Arrow
Bloody Nanosuit
C4 Skin
Chicken Textures-No HD Grass (bug with grass)
Civilian Car Rat skin
Crysis Expanded TOD Files
Crysis HD Textures Pack 2016
Crysis_Moac_Custom_Dark
Crysis W.H. FY69
Crysis FGL40
Crysis FY71 B
Crysis_Gauss_Amphitryon
Crysis Hurricane black custom
Crysis LAW
Crysis Scar Nano Carbon
Crysis_Shotgun_Amphitryon
Crysis_SMG_Old-Used-Look
Crysis Socom Black
Crysis TAC gun us desert
Xzero/Condros/CRYZENX Shaders
Custom Terrain POM Textures
GlobalAmbientLighting_pom_Af
Hawker Tattoo
High Resolution Grass
JP_foods_v2
Laser Pack-RED
LTV red used look skin
Nettle flower
New forest
NK Chinese Camouflage
Pepper's Full weapon sound pack
Pure Blood
Reli2 Installer
Rygel Textures
Radiator
Silents Textures
Slicer91's HD Texture Pack
Starwaster Water Shaders
Tire pom
Ultimate_Assault_Scope
Us soliders
US VTOL seams&bolts skin
Xtreme Particle Chaos
Hmm, not sure if my system will be able to run this..
It's interesting to see how much better this looks than the upcoming COD WW2, but I guess that's using an older engine <trollface>
Can it run Crysis? :sadface:
I decided to try out Blackfire's first on your list and it looks rather nice. I'll gradually work my way through them to see how they compare.
I can also recommend the Maximum Immersion mod if you haven't already experimented with it. I don't know how much of a crossover there is with that and what's in this selection of mods, but it may still be worth checking out. Thanks for putting this together. Those screen shots above look great. :)
Maximum Immersion mod is very good.OK so I used all the mods in the Maximum Immersion mod except
- Rygel's texture pack- Using Crysis HD Textures Pack 2016 which is better and higher resolution.
- NanoSuit Ultra Classic- Using zz_Nanosuit_v2_Gear_With_Attachments which for some reason I forgot to list this one in mod list(I shall fix that).
There are so many mods to use for Crysis game,but there is a problem you can only install so many mods before some stop working ,due to limit in how many mods can be used.
Which config was used to achieve the latter screenshots Gerard? The last 4 especially look incredible.
I used three different maps all at Time of day set to 8am ,by time tthis into console ~.E_time_of_day 8.
The last 5 screenshot were taken on the first map island.
The first four were taken on second map village .
The others were taken on mine map.
Thanks Gerard. :)
It has been a while since I played Crysis (with mods - although I can't remmeber which ones).
This is making me want to install it again right now.
serious question why do people still care about this game? i didn't think it was nothing special. more of a tech demo than a decent game??
It is a video game people like different games that's all.
silly question here were is the predator bow in this package what installer?
I hid the predator bow J/K.I put it as a seperate fie to avoid having two suits overlap.
zz_Nanosuit_v2_Gear_With_Attachments in the Game folder ,So if you just want the predator bow.Open file with 7zip or similar and copy these files into your Game folder.
-Animations\1st_person\weapons\US\Predator_Bow
-objects\weapons\us\Predator_Bow
-Scripts\Entities\Items\XML\Weapons\Predator_Bow_by_Nevil112.xml
-Scripts\Entities\Items\XML\Ammo\StickyArrow.xml
-Sounds\Predator_Bow
