Cheap, dedicated Plex media server?
25 Sep 2011
Staffordshire, UK
I need a small, quiet, dedicated machine that holds the 2x internal HDDs that I already have.
Ideally, it'll be no more than £300 but I think I'm pushing my luck with that price.
My video files are x264 and x265. Mostly 1080p x265 but soon enough, I'll transition to 4k x265.
Transcoding is often used, so I'm guessing I'll need at least a Core i3?
Two clients maximum at any one time (two Chromecasts).
Any ideas?
I use a thinkserver ts140 with a quad-core xeon. They were on cashback and I got it for something like £250-300 with a 1tb her and the Xeon costing that much alone. It holds 5 1080p streams no problem and handles 4k ok too.
If you hunt about there are some good priced units out there or auction sites for a used one. I actually run xpenology on mine and then plex in that. Works a treat
