10+2 for the FTW2, the 14+3 is the classified gaming card. Not that it will likely ever need it.
The fact that the GTX 1080 ti Kingpin has 10+3 shows 14+3 is just overkill.![]()
Out of the two models you have listed, the sc2 has the newer/updated memory (11016 mhz vs the 10k of the older stuff)
Yeah, I didn't know it either initially. Apparently EVGA isn't using the faster memory. They're basically telling you 'Go ahead and see if you can overclock your memory'.
Not really as crude as that, they have released newer bios that you can download and flash that change the memory speed to 11,000mhz for both SC2 and FTW2 so if you want the faster memory speeds then flash the bios.
Reports on the EVGA forums say they are seeing a nice bump in benchmarks so they suspect other changes have happened as well.
Oh I didn't mean it in a negative way. I just wante to pass along what I found out while researching these cards.![]()
course, i was more doing same too
. we'll worth updating bios if you have either of these cards
Pits the ACX vs ICX versions but it'll give you an idea of how the FTW2 compares to the SC2
You are not the only one feeling this mate. It is the only thing that stopped me from picking up a 1080Ti Aorus Xtreme a few days ago.Only thing putting me off is it feels like pascal has been around for ages...but then Volta seems so far away.
I'm also stuck on the fence.Only thing putting me off is it feels like pascal has been around for ages...but then Volta seems so far away.
Having had a 1070 and 1080 feels like buying a 1080Ti now it will be old tech in around 6 months time when everyone will be playing with their nice new shiny Volta. I will grab a 2070 Aorus xtreme on release and then consider grabbing the Volta Titan after when it comes out.
Pascal was pretty much mature on release, I suspect with the resources Nvidia have that Volta will be also. Surely you are not expecting Volta to perform worse than Pascal?...but it is mature. Look at AMD, it is new and shiny yet not delivering for so many.
