The media really ***** me off sometimes
Surely that is a better solution than arbitrarily discrimination against crime victims? Are you really saying that if two houses are burgled and jewellery taken for example, that they should receive different levels of service based on factors unrelated to the crime?
But it is related to the crime or incident. The victim's needs should be taken into account and a victim who is deemed to be particularly vulnerable or requires additional reassurance or other help, safeguards etc should receive that. Someone who doesn't really need follow-up visits or to be put in touch with support services needn't be offered them.
That was an example. Charging for supporting the events and activities where large groups of people are gathered due to an organised event was the actual point, as I am sure you were aware. Make groups responsible for the costs of increasing the risk of crime.
So rather than arbitrarily allowing elderly and disabled people access to the service, you want to charge a fee based on an arbitrary attendance figure?
You are missing the point. It is not about providing an enhanced service to those deemed to meet arbitrary criteria. The proposal reduces service for those who do not meet an arbitrary criteria.
Rather than arbitrarily discriminate against victims of crime, I want to charge those who choose to organise events that increase crime.
A carnival, a football match or a protest March are events that are organised, they are a choice. As such, the organisers should be responsible for the costs.
Yes I'm sure if you try to bill people for holding a protest they will just decide to not have the protest, rather than showing up anyway but with an anti-police sentiment.
The left who hold the violent protests in London tend to turn up with that attitude anyway...
They are not discriminated against. I can give my statement over the phone, a deaf person cannot, they need a face to face interview, I don't. The police cannot attend ever case in-person and maintain other duties, not with the deep cuts.
Billing for protests? Bit authoritarian. We have the right to protest "if you can afford it" isn't really in the remit. Why not charge for other police services? £150 to report a burglary, £2000 if someone tried to kill you.
Citation needed for the above maybe? Perhaps a correlation between time spent on a crime, contact with the victim and resolution rate?
You choose to organise a protest, you don't choose to be a crime victim. A closer comparison would be charging criminals the real costs of investigating their activities. Not as emotive though.
No one at a protest is choosing to be a crime victim either
It reduces services to a level deemed acceptable for those who do not require anything further. There aren't enough resources to attend every call immediately, or provide in-person reassurance or reporting to a victim of crime.
This is how you have to read the news, from most sources (though more with the likes of the Daily Mail and The Sun).
Read between the lines and from multiple sources.
Unfortunately a lot of people will take articles at face value and treat it as gospel, or guide toward their readers' way of thinking. Of course many media oulets/companies take advantage of this and appeal through scaremongering and the like. Sickening really, but what are you going to do?
Dolph ruins every post I make.
Because I don't accept your assumption that because this is being done, it is the only thing that can be done, and therefore must be due to Tory cuts?
I've disputed this and offered an alternative view of what the police could do to balance the budget, based on existing precedent (football clubs already have to pay towards policing near the grounds on match days).
How is that ruining anything? The purpose of debate is not to listen to an echo chamber.
Because you don't understand or won't understand that the cuts are responsible for this.
You haven't provided any evidence of that.
The cuts mean the budget and services need to be reassessed, they do not mean that the met have to discriminate arbitrarily against crime victims.
I've already identified one alternative solution to balancing the books, there are no doubt others. Your position that the only thing that can be done is more money is not backed up by any evidence at all.
You usually come across as a reasonably well informed poster Dolph, but here you are well out of your depth.
They have choices, this is the one they have chosen. It should be criticised the same as it would be if they declared they were not going to investigate crimes as thoroughly where the victim is disabled, or poor, for example.
Remember, this is about investigating crime, not supporting victims of crime. The right to have your crime investigated should not be altered by arbitrary factors in any way.
It makes a lot of sense to prioritise vulnerable victims of crime, indeed most forces are doing this even if they're not putting a press release about it. Forces still prioritize calls based on severity, that will not change. However, when it comes to minor property crimes where there isn't the resource to visit everyone in person it makes sense to prioritise vulnerable victims where the impact to that person may be higher.
Point one, the level of investigation a crime has is decided by the police or indeed whether there is any investigation at all. You have no right to have a crime automatically investigated.
Point two, supporting victims of crime is a legally mandated requirement under the victim code. The whole idea of victim centric investigations is core to modern policing, catching criminals isn't enough anymore.
Most events that require some sort of licence will pay for some of the associated policing costs. The level of charging is dependant on many variables but some information is here: http://www.npcc.police.uk/documents/finance/2015/NPCC Guidelines on Charging for Police Services.pdf
It's worth noting that a protest is very different from a festival. The police have a duty to facilitate protests as it's an important part of the qualified freedom of speech in the UK. The ability to be able to voice a concern should not be predicated on the ability to pay for any incidental policing at these events.
It's just worth making sure this is clear. Police do charge events for policing costs where appropriate and where statute allows.
