PSU is a brand new Seasonic Prime Titanium 850w. I'm running no overclocks or anything fancy. Two of the crashes were at 1 led of load on the card. Which position is the power save BIOS? To the left towards the outside of the case, or to the right pointing inside?![]()
Same here, I went from a Fury Pro to the 1080 and found that I noticed the tearing and juddering a lot more after having got used to Freesync so I will be back with the red team shortly. Plus the compute performance will be better which is a large part of what I actually do with my machine.DPD due at 15:30, will be moving from a gtx1080. 100% side-grade but can use freesync and nvidia drivers have been causing issues with gears of war 4 for a while now.
Plus I like new hardware![]()
I've never used freesync/gsync but from what I've read it should be a great improvement. I currently have the very same 1080 G1 as you do according to your sigSame here, I went from a Fury Pro to the 1080 and found that I noticed the tearing and juddering a lot more after having got used to Freesync so I will be back with the red team shortly. Plus the compute performance will be better which is a large part of what I actually do with my machine.
Freesync is great. I'm not sure whether I notice tearing and judder because my monitor is so much bigger now (34" superwide) or because Freesync has spoiled me. Either way I had to back settings off on the 1080 to keep V-Sync to such an extent that I thought I may as well go VegaI've never used freesync/gsync but from what I've read it should be a great improvement. I currently have the very same 1080 G1 as you do according to your sig
That reminds me, I need to update my sig!
Same here using an ultrawide (Samsung C34F791 - amazing screen). I could never get on with vsync due to the input lag, hence been putting up with screen tearing for a while now.Freesync is great. I'm not sure whether I notice tearing and judder because my monitor is so much bigger now (34" superwide) or because Freesync has spoiled me. Either way I had to back settings off on the 1080 to keep V-Sync to such an extent that I thought I may as well go Vega
