Hey folks, been having a little bit of a head scratcher with my MSI 980Ti gaming 6G.
card works perfectly... apart from the fact the LED logo on the side doesn't illuminate.
thought it could be a dead bulb so took it apart to see whats happening under the hood. It was clean enough and the screw with the MSI seal had not been broken, the thermal paste also appeared to be original.
there appears to be a connector on the top of the board which has nothing attached to it though and on the cooler and shroud there are no additional cables other than the PWM fan control.. no even loose or broken wires where a connector maybe at one point was
looking online the 6G looks like it should have 2 cables coming from the cooler, 1 the fans, and the other a 2 wire cable going to the LED?
I'm a tad confused here and the online retailer I bought it from has since gone the way of the dodo and stopped trading.
being prepared for the fact that he / she may have swapped the cooler (no signs of it though) what do you all think should be the next step?
Used cooler? (what are the options for a direct swap to a Gaming 6 PCB?)
Rewire the LED myself? ( I can see 2 wires going into where the LED is so may be able to do something there)
Its not affecting gameplay in the slightest... just annoys me when something doesn't work and I cant figure it out...
Could it be as simple as MSI had released a non illuminated version?
