Is it possible to re-seal antistatic sleeves
12 May 2011
Southampton
Basically I bought some RAM from eBay and I expected it to be second hand as it is SDR RAM. But it has come in a completely sealed anti-static sleeve thing, so could it be new? Or would it be easy to seal this up.
Random guess... the plastic is heat sealed. Could probably crimp an open one closed with some hot hair straighteners.
Possible? Yes. Theyre often just heat sealed and not hard to do.
Was it worth the seller going to that extent to sell it as new though? How much extra would they have gained.
looks pretty well done if its been done by a random guy with hair straighteners. Dont think id risk the fury of the missus and would just tape it ;)
The jagged and wonky edge at the bottom looks dodgy tbh, if you have the means to melt the two flaps together you could do it. Even if it's second hand it's good to see that the seller has taken all precautions against static.
Well according to the esd training I go through with work we go by if it's not sealed it's useless.
So if they're a serious reseller they might spend the extra couple of quid and get the gear to seal it.
Well I found a bit of common sense in me, and just opened the sleeve and had a look. The RAM has certainly been used as I thought. The seller was nice enough to send a matching pair of sticks though!
I don't believe in that ESD nonsense! I remember years ago at work we were trying to implement some additional monitoring on the installed DIMMs, and i had the fun task of trying to destroy some, we even had a Van De Graff generator which was great fun zapping RAM chips. However plug it back into the server, and hey presto, it still worked.
Haha, well, our exposed boards cost between 70-200k so I'll do everything I'm told while handling them :p
