Exactly, it's basically just a clockspeed bumped 7700k, a bit like the 2600k was or the 4790k. It shouldn't require a new motherboard.I think the lack of coverage on the 7740x is because of peoples opinion of it. It shouldn't exist on a HEDT platform.
latest run with my 24/7 settings; 14702 time spy cpu.
Its a good test for games though to be fair which is its purpose. plenty of other benchmarks for mega core counts11827 is my max at 4.1ghz. Timespy certainly doesn't seem to scale well with cores, Firestrike seems to scale a bit better (31100) but still not great. Wonder if the next 3DMark will be better able to use more cores?
Yeah junk scaling needs a patch to use the cores correctly.Its a good test for games though to be fair which is its purpose. plenty of other benchmarks for mega core counts![]()
That reminds me, what is your Cinebench R15 score now with that 4.8ghz? I maxed out at 3378.Its a good test for games though to be fair which is its purpose. plenty of other benchmarks for mega core counts![]()
So on average they have a similar performance for about the same amount of money. Less heat and less power draw though.Really? like your time spy score?
Maths time: you have 60% more cores than the 7900 and in a fully threaded benchmark have what.. 23% more performance?
in the time spy cpu which is much more indicative of game performance, the 7900x has 24% more performance than the 1950. (in this case)
Hey you are right, that is cute!![]()
Not bad for a company with far, far less r&d and resources.
Which is good, it seems they needed this kick up the backside. After all it allowed you to buy a cpu which otherwise would have likely cost you more than it did.Not bad at all! To be honest, Intel got lazy and this has cost them.
If you do a really crap conversion on those R15 scores, the TR scores 51.49 points per GHz of CPU and the 7900X is at 57.29.
I know it's a pants way of doing a comparison, but if you ignore the number of cores, then you can see what sort performance you are getting for your GHz.
EDIT: An Intel 16 core at 4.8GHz, should be hitting 4400 points!
Depends how high the higher core count chips clock to be honest, cant see them hitting the same as the 6/8/10 core, if they do ill buy one. If only to beat amigas cinebench![]()
