If you can find a second hand 3/3T for quick delivery then go for that. Otherwise, good shout to the G5 Plus dual SIM model. However looking at the reviews on CPW, some are saying it's the single SIM version, while others are saying dual SIM, so you will probably need to check with the staff.
Another cheaper option is the Wileyfox Swift 2 X, which has next day delivery on the rainforest if you have prime.
