Hi there.
Iv run into some issue with my block, pump , and radiator which I wont go into unless you want to know, but Im after some advice on what is the best online UK shop to get all my water cooling parts at the best price but more important good customer service? It seems I email shops and wait for a week to get a reply, and at times a one line answer to part of my question, as if my purchase decisions wont be effected by their poor or slow response?
Edit: It seems this forum is linked to its own shop which I didnt realise. I started water cooling many years ago and my system has been fine for like 7 years so have had no need to be in the loop on forums. Here is my problem.
I have a Aquacomputer Kyros Cluplex, and notice my temps where very high 101c. When looking I found my block to be blocked up with grey stuff. I also noticed that being the first time I ever opened it up that loads of pins where bent? I tried to bend many back but it seems there is quite a bit of resistance when blowing a little less than blowing a baloon, not sure what pressure it should be? May need a new back plate, what options do I have, buy a cheaper version of my block to get the same back plate, or get just a back plate by itself?
When I take the block out the loop the D5 pump seems fine, (its 8 years old) and squeezing the tube I can feel pressure, but with block in the loop I feel nothing (Pins bent?), and it takes ages to get the water to go around system. Has my pump had its day.
After cleaning out the radiator, spend hours on this, Vinigar, hot water, high presure, again today 3 days later pc over heated and found more grey stuff blocking up block. So maybe pump is on its way out, but do I also need a new radiator, and a new back plate for block.
It looks like I may need a new Radiator, block back, and pump, but id like to fix what I have if I can.
Thanks, Dan
Thanks, Dan
