- 3 Mar 2010
- Staffordshire
A settled way of thinking or feeling about something, so I guess its right.That's still an attitude. An attitude is an outlook or way of thinking.
I don't think there is any need to be like that because I didn't do what I was told.Everybody has to learn something new from time to time and changing platforms is no different. If you don't try something out then you will never know. Plenty of people across your multiple threads were advising you to go AMD yet you wouldn't even consider it because you didn't want to try something new. Enjoy your overpriced Intel system and hope that you don't have the same problem as the 7700k and Z270 board that you have already returned.
I appreciate what you say, I just decided to stick with familiarity I guess. I am happy with my choice and did appreciate all the advice. 8 Pack did a bit of a review on this kit and I guess that swung it. I did seriously consider the AMD route but read one review where the chap was having a nightmare and with my luck I thought better of it this time.Sorry, I didn't mean to come across nasty but you asked for advice and most people across your various threads advised you to go with AMD and you just ruled it out because you weren't familiar with it. All it takes is a bit of reading through some up to date reviews and you would have seen that you could have gotten so much more for less money. Why ask for advice if you just go and buy what you already had?
No Asus utilities and its ok
It's a well tested and trusted platform, the 7700k is still a top-notch cpu, it's top of most review charts. I like what amd are doing and if they keep going i'm sure they will gain more trust and confidence in their products for end users, the amd Ryzen memory compatibility issues were off putting from the get go, but it appears they are working on improvements, they still have to play catch up to Intel and Nvidia, but Intel and Nvidia hedt products are expensive.I just decided to stick with familiarity I guess.
. The industry has moved forwards at an amazing pace and continues to do so.It's a well tested and trusted platform, the 7700k is still a top-notch cpu, it's top of most review charts. I like what amd are doing and if they keep going i'm sure they will gain more trust and confidence in their products for end users, the amd Ryzen memory compatibility issues were off putting from the get go, but it appears they are working on improvements, they still have to play catch up to Intel and Nvidia, but Intel and Nvidia hedt products are expensive.
Exactly... The intel option is fine. The amd option is fine. You made your choice and the rig will do your tasks fine. I don't understand these people at all..I don't think there is any need to be like that because I didn't do what I was told.
