Does anyone own the Gigabyte 1080ti Aorus waterforce extreme?
16 Jun 2013
Horrible name but I was hoping someone could tell me what video connections/adaptors are in the box?
I've got a mini-dp to vga adaptor for an older monitor and need to know if I have to buy new cables again :(.
Side note: Does anyone know how the waterblock compares to an EK one? It looks to be a standard 1/4" fitting.
Tried embedding video but failed. But shows unboxing of the full waterblock aorus ti(which I just bought 2m old one) and no extra connections included.
Balls will need new cables then. Thank you for that.
Clearly didn't google well enough :(.
Yeah going for the non aio one. Hopefully won't have to muck around with the loop too much this way :).
If you can afford that card, you can afford a new cable :p ;)
:D Was more about wasting cables. I have an obscene amount of cables that are useless to me now.
Also the annoying testing of finding out what adaptor works with the card or doesn't. I went through at least 3 mini dp to vga adaptors trying to find one that worked last time :(.
found a solution to your problem
My basket at Overclockers UK:
Total: £911.09
(includes shipping: £11.10)
I have a sack....as in a santa sack sized sack, full of every lead that has been used since the 90's. My wife is forever threatening to chuck it out. I know I@ll never use 90% of them again but it's almost hobby level collecting them now lol.
Glad I'm not the only one :D.
I don't suppose anyone knows what the thermal paste they include in the box is?
Wondering if I can use it on my CPU as well :confused:.
Seems my artic silver has gone crusty :(.
