Hi guys,
This is going to make me sound like an absolute idiot but happy to take one for the team...
Just moved into a New Build. It has:
At first I thought each floor of the house was controlled by the thermostats. Heating would only come on when they called for heat. The TRVs would only allow hot water into the radiator when the dedicated thermostat requested it and the temperature was below the room TRV temperature.
Until... I found another single timer in the boiler cupboard. It says "CH", which to me would mean central heating. I called the house builder and asked what it was for. They called the plumbers and told me "it's for the hot water. Leave it on all of the time". What? What is the point in a timer for hot water if I need to leave it on? I have always had hot water since I moved in but the timer is showing as off... so how does that work?
Then, I opened the megaflo cupboard and saw an electric switch on the wall is on. What is the switch for? What is the megaflo for? Have I been using electricity to power my hot water rather than gas? I don't think so because when all of the thermostats are off and I turn on a tap, the boiler kicks in.
Surely making a nuclear bomb is less complicated than this stupid system??
- a condensing boiler,
- two zoned thermostats with timers for high, medium, and low temperature,
- radiators with TRVs except the two zones, and
- a megaflo system (eco unvented indirect cylinder)
